Troubleshoot MicroStation CONNECT Edition Installation Known Errors
  Product(s): MicroStation
  Version(s): V8i, CONNECT Edition MicroStation 2023 - 26
  Environment: N\A
  Area: Installation
  Subarea: Troubleshoot New Installations (Single Users)
MicroStation CONNECT Edition Further Troubleshooting and Know Errors
The following document offers some steps to Troubleshoot common problems encountered when installing MicroStation CONNECT Edition along with some known issues.
Please consult with your IT or CAD/SITE Administrator if you have one prior to making any changes.
CHECK SYSTEM REQUIREMENTS
The first step with any application installation trouble shooting is to ensure the version being installed is compatible with the platform on which it is to be run.
In addition to this that it’s also compatible with other required applications such as ProjectWise.
INSTALLATION METHOD REQUIREMENTS
Having identified the correct version, the next step is understanding how the application is being installed, the method used may determine the cause of a problem
That said of course some issues encountered may be generic irrespective of the method chosen.
Here are some Common Generic Issues:
TYPE OF INSTALLATION
Another influence on the types of issue encountered may be down to if it’s a new Install, an upgrade of existing version or upgrade from an older version.
New installs being more straight forward, but if upgrading whilst the install may appear to go well, it could be that the previous version files were left behind and hinder the functionality.
POST INSTALLATION
Check the Installation Log Files, if needing further assistance understanding these or unable to resolve use the link below.
Known Issues and additional Resources:
Help
Documentation
 Blogs
CONNECT Wikis
Installation Guide
MicroStation - Error 0x80070006 when installing MicroStation
Installation failed with error code 0x80070020
Is Package Cache needed?
How to change the Package Cache location
MicroStation CONNECT will not install
MicroStation CONNECT Edition will not start
Where can I find the installation log file for MicroStation Connect?
Where can I find the installation log for my Bentley product?
Pre CONNECT
                               Error VBA not installed fatal error
"The installation failed with error code 1642"
This computer has not been restarted since this program was installed
Error-1638-installing-prerequisite-pack
Exception-log-with-io-error-sscloud-ma
Installation of MicroStation hangs
MicroStation 8.5 freeze when installing. Corrupt Install Shield
Minor version mismatch warning
Why are Random Folders created under All Users and Local User profile?
V8i installation Overwrites Previous Version
Return to
New Installations (Multiple Users)
Requesting Further Assistance
Other language sources
