| Issue status | Solved |
| First Affected Version | PLAXIS 2D CONNECT Edition V22.01 PLAXIS 3D CONNECT Edition V22.01 |
| Found in Version | PLAXIS 2D CONNECT Edition V22.01 and V22.02 PLAXIS 2D 2023.01 and 2023.02 PLAXIS 3D CONNECT Edition V22.01 and V22.02 PLAXIS 3D 2023.01 and 2023.02 |
| Fixed and Released in Version | PLAXIS 2D 2023.2.1 |
| Issue # | 1230624 |
| Date created | 31 August 2023 |
| Date modified | 12 October 2023 |
Groups that are created in PLAXIS green modes were lost when reloading the project. The PLAXIS green modes are Mesh mode, Flow conditions, and Staged construction.
Figure 1. Creating a group of selected objects in Staged construction
This issue is now solved in PLAXIS 2D/3D 2023.2.1.
In the above-mentioned affected versions, the only workaround is to create the necessary groups in Structures mode.
However, for groups that include elements produced/generated after the geometry has been intersected in green mode, this is not applicable.
The workaround for such cases is:
group (Point_1_1 Line_1_1 Line_1_2)
