| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot New Installations (Multiple Users) |
MicroStation CONNECT Edition can be installed from a defined ‘Deployment image‘ pushed via SMS/SCCM. This process is managed by your Site Administrator or IT department, thus you should contact them in the first instance if encountering issues.
However the New Installations (Single Users) may provide some additional help, along with the following resources:
Here are some further resources regarding the Installation of Deployment images
Help
Blogs
Wikis
Return to
