| Application | PLAXIS 2D Leapfrog Works Central |
| Version | PLAXIS 2D 2023.2 |
| Date created | 26 October 2023 |
| Date modified | 26 October 2023 |
The following video illustrates Seequent’s Connected Geotechnical Workflow between Leapfrog, PLAXIS and Central.
This latest release solidifies Seequent's Connected Geotechnical Workflow, reducing the need for duplicate entry of data across several software packages. To illustrate this workflow, the video below uses a tailings storage facility model that was pre-designed in Leapfrog and imported into PLAXIS for geotechnical analysis
Summary of the video:
