| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Updating MicroStation CONNECT Edition Installations |
Having created a new Deployment Image from a new Update, the executable from the Deployment Image can be run to Update the previously installed MicroStation CONNECT Edition Update.
The process follows the same principle as updating from a downloaded executable explained in the Manually Upgrading MicroStation CONNECT Edition article
But its important to check the prerequisites have not changed and that the Update is compatible with other application installed such as ProjectWise before proceeding. This and other installation information can be found in the Troubleshoot New Installations (Single Users) article.
Should you encounter problems during the update install, please contact your Site Administrator in the first instance. If requiring further assistance collate the Installation logs and raise a Service Request with Bentley ( See link below )
Here are some resources to help you with installing MicroStation CONNECT Edition from downloaded executable.
Help
Blogs
CONNECT Wikis
Pre CONNECT
Return to
