This section contains videos of the PLAXIS 2D and PLAXIS 3D.
Are you ready to start with PLAXIS? This page shows the getting starting training video sets to quickly be up to speed for PLAXIS 2D and PLAXIS 3D!
This page list an overview of recent on-demand learning sessions for Bentley Geotechnical Engineering and PLAXIS
Since PLAXIS 2D 2023.1, you can now add rock bolts and cable elements for your tunnel reinforcements.
With an easy to use Calculation manager for PLAXIS 2D and PLAXIS 3D, you can queue up your calculations quickly and efficiently!
- vip, validation, tunnel, rock, jointed rock, field stress, circular, anisotropy, anisotropic, PLAXIS vip, PLAXIS 2D
- tags:
Using the Command Auto-Complete you will be more efficiently, make fewer mistakes and save time when using the PLAXIS 2D/3D Command line
- triangulation, surface, step, rhinoceros, rhino 3d, rhino, parametric geometry, parametric, nurbs, importing surface, import, geometry, dxf, PLAXIS 3D
- tags:
It is now easier to deal with imported geometry in PLAXIS 2D: decompose any shape into their outline segments. Watch this short video!
PLAXIS now offers export to ParaView for advanced post-processing. We posted some instructional videos. Available as Technology Preview.
The Field Stress initial calculation type allows specifying in situ stress conditions: input the initial stress state by magnitude and orientation.
In this video, we will guide you on how to import CPT data to be used for your PLAXIS soil layers using the Field data option in the borehole.
This demonstration video intends to illustrate the use of movement functions to simulate a train passing through a rail track over an embankment.
This video shows you how to plot curves for multiple phases in different colours in PLAXIS Output.
The videos below demonstrate a practical workflow for comparing a reference phase with a target phase and identifying differences in the activation status of model objects in PLAXIS 2D and PLAXIS 3D.
This video intends to illustrate how to use the command log files in PLAXIS.
This demonstration video intends to illustrate modelling strategies on how to use PLAXIS 3D tools to design a shaft foundation with reinforcements.
This short video shows how importing Leapfrog geological cross sections from Seequent Central into PLAXIS 2D can help you
- seequent, leapfrog, interoperability, import, geometry, geology, geological model, cross section, connected workflow, central, PLAXIS 2D
- tags:
In this video, we will demonstrate how to import your Leapfrog Geological Model into PLAXIS 2D
- step, rhinoceros, rhino 3d, rhino, parametric geometry, nurbs, import, geometry, dxf, cad, autocad civil 3d, autocad, PLAXIS 3D
- tags:
From Microstation to PLAXIS: importing CAD geometry efficiently and quickly.
Using Limit Equilibrium and Finite Elements has never been easier when using PLAXIS.
- reliable, refine, quality, optimizing, mesh quality, mesh, generate, element, efficient, coarseness, coarse, PLAXIS 3D
- tags:
The following video illustrates Seequent's Connected Geotechnical Workflow between Leapfrog, PLAXIS and Central.
This short video shows how to get your mining drift from Seequent Leapfrog + Central into PLAXIS 2D
- seequent, rock, mining, leapfrog, interoperability, import, geometry, drift, connected workflow, central, PLAXIS 2D
- tags:
We now offer the ability to convert older PLAXIS 2D files: now you can directly get PLAXIS files with the *.P2D in the latest PLAXIS version!
This video will guide you through the process regarding the new PLAXIS V21 licensing changes tailored to the needs of every geotechnical engineer.
- tutorial, stress, strain, soiltest, soil, oedometer, laboratory, lab, failure envelope, dss, crs, chart, PLAXIS 3D, PLAXIS 2D
- tags:
PLAXIS integrates with Bentley Systems' ProjectWise: collaborate on PLAXIS 2D/3D models through ProjectWise to unlock enhanced collaboration!
The Polycurve designer can be used to quickly create pipes, simple tunnels, piles and offshore foundations
- ucs, triaxial, test, soil, shear, prescribed, fixed, earthworks, displacement, clay, PLAXIS 3D
- tags:
- triaxial, soiltest, sensitivity, parameters, parameter variation, optimizing, optimisation, oedometer, laboratory, lab, PLAXIS 2D
- tags:
Calibrate unsaturated soil modelling with Barcelona Basic: use SoilTest with suction definition
This movie shows how to use and apply interface permeabilities
This movies shows how to use the multiply command
