| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Updating MicroStation CONNECT Edition Installations |
Having installed MicroStation CONNECT Edition previously. Notification and Delivery of an Update can be performed via the CONNECTION Client ( Assuming Internet connection and permissions etc. are in place. ( See also CONNECTION CLIENT FAQ )). Note it will deliver the latest available Update.
This article describes the process of How to install MicroStation CONNECT Edition Updates via CONNECTION Client
Should you encounter problems during the update install, please contact your Site Administrator in the first instance. If requiring further assistance collate the Installation logs and raise a Service Request with Bentley ( See link below )
Here are some resources to help you with installing MicroStation CONNECT Edition via the CONNECTION Client.
Help
Installing MicroStation CONNECT Edition from CONNECTION Client
Blogs
Which version is offered by automatic update?
CONNECT Wikis
Installing MicroStation CONNECT Edition from CONNECTION CLIENT
How to install MicroStation CONNECT Edition Updates via Connection Client signing in issues
Pre CONNECT
Return to
