| Version(s): | 10.15.00.74 | ||
| Area: | Installation | ||
| Subarea: | Updating MicroStation CONNECT Edition Installations |
MicroStation CONNECT Edition can be Updated from a defined ‘Deployment Image‘ pushed via SMS/SCCM. This process is managed by your Site Administrator or IT department, thus you should contact them in the first instance if encountering issues.
However the New Installations (Single Users) may provide some additional help, along with the following resources:
Help
Blogs
CONNECT Wikis
Pre CONNECT
Return to
