| Version: | CONNECT, 2023 | ||
| Area: | Configuration | ||
| Subarea: | General |
Have you ever wanted to view extended configuration information but did not want to run a debug?
Access configuration information more quickly and easily from within MicroStation by using the show configuration key-in.
As an alternate to running a MicroStation debug, the show configuration key-in can provide basic configuration information from within the application. This can be used to quickly verify the current value of various configuration variables such as MS_CELL, MS_DGNLIBLIST, MS_SEEDFILES and more.
To use the show configuration key-in:
A text file is generated (configVariables.txt) and displayed within your default text editor. This file may then be saved, if desired, to the location of your choosing.
