Supported Connections List
Back to Product Wiki
Below devices and sensors are integrated into the iTwin IoT platform. These devices and sensors are added as Connections directly in the application or through a file transfer process. Vibrating wire logging devices all support the vibrating wire sensors listed here.
Cell or Radio Connections added directly to iTwin IoT Application
Geokon Geonet 8800 Series Logger
Geokon Geonet 8900 Series Logger
Sensemetrics Strand VW4
Worldsensing Thread
Worldsensing Loadsensing G6 Gateway
API Connections
Ackcio API Connection
  • Ackcio Analog Communication Beam Node
  • Ackcio Digital Beam Tiltmeter
  • Ackcio Vibrating Wire Beam Node
  • Ackcio MDT MPBX
Instantel Thor Micromate
Move Solutions API Connection
  • Move Solutions Accelerometer SHM
  • Move Solutions Analog Communication Node
  • Move Solutions Deck Dynamic Displacement Device
  • Move Solutions Digital Communication Node
  • Move Solutions Gateway
  • Move Solutions Single Channel Node
  • Move Solutions Wireless Tilt Beam
  • Move Solutions Wireless Triaxial Tiltmeter
  • Move Solutions Wireless Vibrometer
Viotel API Connection
  • Viotel Accelerometer
  • Viotel Tiltmeter
Worldsensing CMT Edge API Connection
  • Measurand Shape Array
  • Sisgeo BH-profile In-Place-Inclinometer
    Sisgeo LT-Inclibus
  • Sisgeo Tiltmeter
  • Sisgeo Rail Deformation System (RDS)
  • Sisgeo H-Level
  • Sisgeo Anchor Load-Cell
  • Sisgeo Digitized 1-Base Point Rod Extensometer
  • Sisgeo Digitized 2-Base Point Rod electrical MPBX or MEXID Extensometer
  • Sisgeo Extensometer probe (DEX)
  • Sisgeo Extenso-Inclinometer probe (DEX-S)
  • Sisgeo Digitized 3-Base Point Rod electrical MPBX or MEXID Extensometer
  • Sisgeo Digitized 4-Base Point Rod electrical MPBX or MEXID Extensometer
  • Sisgeo Digitized 5-Base Point Rod electrical MPBX or MEXID Extensometer
  • Sisgeo Digitized 6-Base Point Rod electrical MPBX or MEXID Extensometer
  • Sisgeo Digitized 7-Base Point Rod electrical MPBX or MEXID Extensometer
  • Worldsensing Analog 4-channel LS-G6-ANALOG-4
  • Worldsensing Digital Logger LS-G6-DIG-2
  • Worldsensing Laser Distance Meter LS-G6-LASER
  • Worldsensing Piconode LS-G6-PICO
  • Worldsensing Tilt Meter LS-G6-LAS-TIL90
  • Worldsensing Tilt Meter LS-TIL90-X
  • Worldsensing Tilt Meter LS-G6-TIL90-I
  • Worldsensing LS-G6-Pico Logger
  • Worldsensing Vibrating Wire 5-Channel LS-G6-VW
MQTT Connections
Worldsensing CMT Edge MQTT Connection
  • Sisgeo LT-Inclibus
  • Sisgeo Tiltmeter
  • Sisgeo H-Level
Worldsensing CMT Cloud MQTT Connection
  • Sisgeo Tiltmeter
  • Sisgeo H-Level
FTP Connections
Senceive Tiltmeter
Trimble T4D Survey Data
Other Connection Types
Kinemetrics ETNA2 Accelerograph
Leica Spider GNSS Data
Leica GeoMos Survey Data
