| Application | PLAXIS 3D |
| Version | PLAXIS 3D AE and later |
| Date created | 09 May 2011 |
| Date modified | 20 November 2023 |
The movie shows how to use the commands runner for more efficient modelling. The generation of a circular pile field was used as an example. The commands are set up in a spreadsheet and run in the commands runner, which can be found under the Expert>Run commands menu option in the PLAXIS application.
