| Version: | V8, XM, V8i, CONNECT, 2023 | ||
| Area: | Printing and Plotting | ||
| Subarea: | N\A |
Problem Description
How can I prevent the file property "Date Modified" in Windows Explorer is not affected by printing a drawing with MicroStation?
As a prerequisite you have to switch OFF the following preferences in MicroStation -> Workspace -> Preferences … > Category: Operation :
Save Settings on Exit
Automatically Save Design Changes
Now you can go to MicroStation -> Workspace -> Configuration …-> and add the following variable:
Variable: MS_PLT_SET_LAST_PRINTED_TIME
New value: 0
This variable prevents that the file property "Date Modified" in Windows Explorer is changed when you only print with MicroStation.
| Original Author: | Frank Reimann |
