Seequent Learning Center - on-demand video training courses
The Seequent Learning Center is the online learning environment of Seequent, the Bentley Subsurface Company.
On this platform, you will find online learning paths and courses to kickstart your learning. It will help you to master key concepts, tools, and effective workflows using the Seequent subsurface portfolio, including software such as Leapfrog, Central, OpenGround, Oasis Montaj, and GeoStudio and PLAXIS.
The Seequent Learning Center can be found here:
https://lms.seequentlearning.com/
There are two options to gain access to the Seequent Learning Center:
  1. Use your Bentley ID (recommended)
  2. Create a free account
Log in using Bentley ID (recommended)
To gain access to the platform using your Bentley ID, follow these steps:
  1. Go to https://lms.seequentlearning.com/
  2. Select Sign in option: use Bentley ID
    Log in by selected Bentley ID
  3. Selecting Bentley ID gives you the Bentley Login webpage:
    Bentley account login page
  4. Use your Bentley ID. This is the same user account / email address as when using PLAXIS or GeoStudio software.
  5. After successfully logging in to the Seequent Learning Platform, you can access the learning content on the Seequent Learning Center.
Alternatively, you can create a free account. Note that for guided trainings, company email addresses are usually required.
See also
