| Version: | V8i, CONNECT, 2023 | ||
| Area: | Printing and Plotting | ||
| Subarea: | N\A |
In Print Organizer when I use a "Named Expression" in my pen table in the Text
Substitution Replacement field, I get the following plotted on the output:
invalid expression
the same Pen Table works from the Print dialog box
Issue was caused by not defining the same arguments used to start MicroStation in the printing variable:
MS_PLT_ENGINE_CMDLINE_ARGS
Not having these arguments caused the .dgnlib which housed the “Named Expression” not to load
when the worker MicroStation was started hence the Named Expression was not being found.
| Original Author: | Ed Yepes |
