Onboarding PLAXIS training videos
This page lists a number of on-demand training sessions. For topic-specific content, please also see our overview of Learning with PLAXIS - on-demand - Webinars and Coffee Corners
Getting Started with PLAXIS 2D
This training unit introduces the PLAXIS 2D program and its workflow. Using the example of a deep excavation analysis, we will cover how to set up soil layers, structural elements, generate the mesh, define flow conditions and set up the staged construction. After the calculation, we will have a look at the results.
Watch the training on YouTube here
PLAXIS Automation Basics: Getting started
PLAXIS Training: Getting started with Automation
If you are getting started with automation using PLAXIS 2D and PLAXIS 3D for your geotechnical analysis, this PLAXIS Automation Basics course will give you a quick start.
This training session introduces PLAXIS Automation and its benefits. Understanding the command line and object structure, we will use automation to define geometry, staged construction phases, materials, retrieve calculation results and more. This series also covers some basics of Python 3, using together Input and Output programs, as well as our detailed Scripting documentation.
Watch the training here *
* requires (free) Seequent Learning Center access, see here for instructions.
ACCELERATE Geotechnical Analysis: an introduction to PLAXIS 2D (2020)
This online introduction course to PLAXIS 2D from 2020 aims to give novice users a quick start in using the software. The training course consists of four (4) sessions of approximately three (3) hours each. Sessions one and two mainly focus on the functionality of PLAXIS 2D while sessions three and four focus on one of the most important and also most difficult part of geotechnical analysis: obtaining soil parameters.
See more details here
Accelerate PLAXIS: Sesiones en español (2020)
Bienvenido(a) a este especial de 4 seminarios virtuales de Bentley Systems, una experiencia única que le ayudará a optimizar y máximizar sus recursos y alcanzar con confianza el éxito de sus proyectos geotécnicos.
ACCELERATE PLAXIS: Sessioni in Italiano (2020)
Benvenuti ad ACCELERATE PLAXIS in Italiano, un speciale di 2 webinar di Bentley Systems che vi aiuterà a ottimizzare e massimizzare le vostre risorse e a raggiungere con fiducia il successo nei vostri progetti geotecnici.
