| Version: | CONNECT, 2023 | ||
| Area: | Configuration | ||
| Subarea: | User Preferences |
The commands listed in the V8i Task dialog are no longer visible.
Verify whether the path specified by the variable MS_GUIDGNLIBLIST points to the dgnlib file (V8iTasks.dgnlib).
The default path for V8iTasks.dgnlib is:
C:\Program Files\Bentley\MicroStation 2023\MicroStation\Default\GUI\Archive\en
If the MS_GUIDGNLIBLIST variable has been properly set, it might be worth trying to Reset the User Prefs directory.
Resetting MicroStation's preference data will reset the customized tools/menu layout as well as the user preferences set in several menus (DWG save options, Personal Preferences menu, etc.) to factory default settings.
Remember to create a backup of your Pref folder in case this process does not solve the issue.
Restore MicroStation to Factory defaults
How To Reset User Preferences and Delete MicroStation's Temporary Files
Other Language Sources
