| Version(s): | CONNECT Edition, 2023 | ||
| Area: | Installation | ||
| Subarea: | Troubleshoot |
1. MICROSTATION SYSTEM REQUIREMENTS
The first step with any application installation is to ensure that it is compatible with the platform on which it is to be run, MicroStation CONNECT Edition is no different.
It is important to note the requirements may change with Application Updates, so check the latest documentation
In addition, ensure the version being installed is compatible with other Applications that may be installed such as ProjectWise
This article will assist you in finding the technical requirements.
Software is typically downloaded from the CONNECT portal, although the version required may not be available or you may not have permission to install.
Your IT CAD/Site Administrator may also have already downloaded and preconfigured for your Organization so please contact them in the first instance.
3. INSTALLING DOWNLOADED SOFTWARE
This article will provide you with Information on installing MicroStation CONNECT Edition Language packs along with troubleshooting tips.
This article will provide you with resources on pointing your install to an Organizational Configuration.
Whilst this can be done during the Installation process, manual Configuration changes can be made later by editing Configuration file(s).
6. ACTIVATION
This article is for those users who which to run MicroStation within a Virtual Environment
8. KNOWN ERRORS & TROUBLE SHOOTING
This article provides you with information on some known issues, and troubleshooting tips that may be encountered when installing MicroStation CONNECT Edition
9. UNINSTALL
This article provides you with information on uninstalling MicroStation CONNECT Edition
