| | Product(s): | MicroStation | |
| | Version(s): | CONNECT Edition, 2023 | |
| | Environment: | N\A | |
| | Area: | Installation | |
| | Subarea: | Troubleshoot | |
Updating MicroStation CONNECT Edition Installations
The following document describes trouble shooting tips and resources relating to carrying out MicroStation CONNECT Edition Updates.
It is advisable to speak with your IT or CAD/SITE Administrator if you have one prior to installing an Update of MicroStation Edition.
There are a few ways in which MicroStation CONNECT Edition can be updated to a newer version, from uninstalling the previous version, followed by installing the new version, to updating via the CONNECTION CLIENT.
The first thing you should check is that the System Requirements have not changed and that the Update is compatible with other applications such as ProjectWise.
Click the area heading to which you require assistance
1. MANUALLY UPGRADING
This article will provide information on performing Updates via a downloaded Executable
2. UPGRADING VIA DEPLOYMENT IMAGE
This article will provide information on performing Updates Deployment Images created by an Organizations IT or CAD/SITE Administrator
3. UPGRADING VIA CONNECTION CLIENT
This article will provide information on performing Updates via the CONNECTION CLIENT
4. UPGRADING VIA SMS/SCCM
This article will provide information on performing Updates via the SMS/SCCM provide by your IT or CAD/SITE Administrator
Other language sources
Deutsch
