| Version(s): | Connect, 2023 | ||
| Area: | Reference | ||
| Subarea: | Attach iTwin |
MicroStation Crashes with Attach iTwin Tool
From User...
After clicking on "Attach iTwin" icon, in Collaborate tab, MicroStation has stopped working and closing.
Call Stack
# RetAddr : Args to Child : Call Site
00 00007ff8`8cc8e1fd : 00000000`e0434352 0000007f`079fd8f8 00000270`e35d4c70 00007ff8`8d4366e0 : KERNELBASE!RaiseException+0x69
01 00007ff8`8cc8f884 : 00000000`00000050 00007ff8`8cc54f50 00000000`00000001 00000270`e3317cd0 : clr!RaiseTheExceptionInternalOnly+0x31f
Unable to load image C:\Windows\assembly\NativeImages_v4.0.30319_64\mscorlib\4bc5e5252873c08797895d5b6fe6ddfd\mscorlib.ni.dll, Win32 error 0n2
02 00007ff8`8c0fbeb4 : 00000270`e35d4ae8 00000270`e35d4c70 00000270`e35d4c70 00007ff8`2d653020 : clr!IL_Throw+0x114
03 00000270`e35d4ae8 : 00000270`e35d4c70 00000270`e35d4c70 00007ff8`2d653020 00000270`00000017 : mscorlib_ni![COLD] System.Security.Permissions.FileIOPermission.EmulateFileIOPermissionChecks(System.String)$##6002621+0x90
04 00000270`e35d4c70 : 00000270`e35d4c70 00007ff8`2d653020 00000270`00000017 00000270`e35d4610 : 0x00000270`e35d4ae8
Retrieved MicroStation Configuration Log by executing the Show Configuration command.
Configuration variable _USTN_WORKSET_IMODELS was pointing to a location with no R/W access.
_USTN_WORKSET_IMODELS = pw://yyy-pw.bentley.com:yyy-pw-01/Documents/EDMS/WorkSpaceName/WorkSetName/Workspaces/WorkSets/iModels/
Resetting the variable value to a local drive fixed the issue.
_USTN_WORKSET_IMODELS = c:\bms\cpk-pw-01\{UserName}\dms67861\iModels\
Collaborate Tab and Attach iTwin tool
| Original Author: | Leonard Jones |
