| Version(s): | CONNECT, 202X | ||
| Area: | Open/Save | ||
| Subarea: | Performance |
Lag/Freeze on file open or file switching.
Check Message Center for reported issues.
In this case, Large Level Name dictionaries were encountered.
Performance can be significantly improved by compressing the file with following compress options:
Note: All compress options can be selectively used. But backup your file.
| Original Author: | Leonard Jones |
