| Version(s): | Connect, 2023 | ||
| Area: | Exception | ||
| Subarea: | N\A |
MicroStation Quits Immediately on Launch
Note: Kindly contact your Antivirus vendor and request for details on threats, security issues reported on Bentley Products.
Share the data by logging a Service Request so our Support team can review them.
Do also share the Event logs - check video.
Whitelisting the known files/folders in the antivirus software had no impact on the issue. Check Wiki
Cautionary workaround:
C:\Windows\system32\hmpalert.dll
Some Users have confirmed adding the following application path via Exclusion Type “Exploit Mitigation (Windows)”. Check link
C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe
C:\Program Files\Bentley\MicroStation 2023\MicroStation\microstation.exe
We recommend contacting Sophos support and troubleshoot to identify the root cause.
| Original Author: | Leonard Jones |
