Is PLAXIS 3D 64-bit?
ApplicationPLAXIS 3D
VersionPLAXIS 3D
Date created30 May 2011
Date modified30 May 2011
Yes, it is. The PLAXIS 3D program is only available as a 64-bit application:
This also means a user-defined soil model should be compiled as a 64-bit DLL.
See also
