| Version(s): | All | ||
| Area: | Text | ||
| Subarea: | Fonts |
Is it possible to use True Type fonts from different directory than C:/Windows/Fonts/ ?
Yes, the MS_FONTPATH configuration variable can be set to point to alternative directories which contain true type fonts.
MS_TTFPATH can also be used on older versions of MicroStation.
These variables will specify the paths to the directories which contain True Type fonts.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108247
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108138
