| Version: | V8i, CONNECT, 2023 | ||
| Area: | Sheet Composition | ||
| Subarea: | Drawing Boundaries |
When a reference is attached to a sheet model, a linked annotation to the drawing outline is displayed. How can this be switched off?
The display of this is called "Annotation Display" and can be switched off using the following procedure:
Toolbox "Detailing Symbol Styles" (Drawing > Annotation) > Select style: "Default" > Drawing Boundary > Annotation Display > Change from "Visible" to "Hidden" and save style
With Boundary Display, you can show or hide the boundary display of the Drawing Boundary. If it is hidden then the user will not see any boundary.
With Annotation Display, you can show or hide the actual drawing boundary annotation, that consists of the bubble and title. If it is hidden, you will not see the Drawing Boundary annotations.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0110245
