Asset Configuration Page Overview
Back to Product Wiki
The Asset Configuration Page holds a number of tools that administrators can use to set up and manage an Asset. This article will review those options and provide links to more comprehensive articles written for each section. The Asset Configuration page can be accessed by clicking the menu icon in the upper right corner, selecting "Organization and Asset settings".
This article will cover the following elements of the Asset Configuration page:
Configuration Tiles
The following sections will provide an overview of the Configuration tiles available in the middle of the window.
1. General settings
The General Information page allows for configuration options related to the Asset.
1. Name
User can configure the name of the asset here. The name will be displayed as such on the asset list as well as the asset select drop-down.
2. Location
Location displays the latitude and longitude of the asset and will be the default view of the asset in the iTwin viewer. The input will act as the center of the asset on the map. GPS location will also be used as a reference for the weather widget.
Note: The latitude and longitude can not be manually entered and must be set using the Asset extent map tool (7).
3. Cover Picture
User can upload an image with the file types jpeg., jpg., and png.. The maximum size of the image is 5 MB. The cover picture is present on the asset selection page as well as the home page.
4. Time Zone
Allows user to set the time zone of the asset location.
5. Data center location
Allows user to enter where the data center of the asset is, as it may differ from the asset location.
6. Team Member Management
Dictates where the project allows members outside of the IMS user database.
7. Asset Extent
A map tool that allows the user to draw the extent of the asset on a world map. The input here will be reflected in the location latitude and longitude field.
*note: Users must enter a map location when creating an asset.
2. Users and Roles
Allows the invitation of users and the editing of their roles and permissions throughout the asset.
Please refer to the following article for detailed information: User Management
3. As-Built Reality Models
Allows users with the appropriate permissions to associate As-built Reality Models to the asset.
Please refer to the following article for detailed information: As-Built Reality Models
4. As-Designed Models
Allows users to create iModels and connect them to the asset.
Please refer to the following article for detailed information: As-Designed Models
5. Billing and Tokens
Allows users to monitor asset token usage, start and end date, data usage, and module licensing. Only Admin-level permission will see this section.
Please refer to the following article for detailed information: Billing and Tokens Page
6. API Key
The exposed API key can be copied to be used for API connections.
Please refer to the following article for detailed information: API Connections
