| Version: | V8i, CONNECT, 202X | ||
| Area: | Reference | ||
| Subarea: | N\A |
Text, Dimensions, etc. scale when attached as a reference.
When a Model containing Text, Dimensions, etc. is attached as a reference to another model, these elements in the reference are too big and are scaled up. When opened on their own, the elements display normally.
The text when placed in the original file has been placed with the Annotation Scale Lock switch on. This means any annotative elements placed with this lock on will respond to a change in annotation scale in the active master file model.
To set the reference text back to desired (normal) scale, this setting must be turned off.
Annotation Scale and the Drawing Scale Dialog - Blog
Annotation Scale simplified - Wiki
| Original Author: | Conor King |
