GeoStudio Add-Ins can be used in place of any internal GeoStudio function (such as those under the Define menu) or a SIGMA/W material model. The Add-Ins listed below are ready to useājust install them with the Add-In Software Development Kit and restart GeoStudio. You can also write your own using the resources provided in the Add-In Software Development Kit.
GeoStudio can be used with PEST for parameter estimation problems. See the example file for instructions on how to use PEST with GeoStudio.
