This section contains the example files that were created to verify the GeoStudio formulation. The verification and benchmark example files are available as part of a larger example set and can be downloaded at the links below. (A Seequent or Bentley ID is required to access these files. For information on how to create a Seequent ID click here.)
- Limit Equilibrium Formulation
- Hand Calculations
- Radial Flow to a Well
- Lab Sandbox Problem
- Infiltration into Dry Soil
- Water Convection - Horton-Rogers-Lapwood
- Kisch Clay Liner Problem
- 1D Consolidation
- Bars in a Truss
- Beams and Bars in a Frame
- Bishop Pore Water Pressure Coefficient
- Pore Water Pressure Response of an Unsaturated 1D Column
- Strength Reduction Stability
- Forced Convection with Water Including Freezing
- Neumann Solution to Phase Change Problem
- Heated Closed System
- Henry Saltwater Intrusion
- Closed-Form Equation Comparisons
- Air Convection
- Proshake Comparison
- Structural Beams
- Vibrating Beam
