Product(s): | MicroStation | ||
Version(s): | 10.01.00.13 | ||
Environment: | N\A | ||
Area: | Interchange | ||
Subarea: | OBJ |
Working with OBJ files in MicroStation
OBJ is an open geometry definition file format (.OBJ) that is available in various software applications.
You can export a DGN file to OBJ format.
There are several options available when you open an OBJ file:
When working with OBJ files, OBJ files use the master units of the file defined by the MS_TRANSEED configuration variable.
No new levels are created.
No new colors are created because OBJ files do not specify color.
If you choose to import materials, they are stored in the DGN file.
Texture files remain in their original location, they are referred to by an absolute or relative path.
Original Author: | Anders OMahony |
