Reference attachment is red.
  Product: MicroStation
  Version: V8i, CONNECT, 2023 - 2025
  Environment: N\A
  Area: Reference
  Subarea: N\A
My reference files are not showing up when I open a file.
If reference is RED (not resolved) in reference dialog:
Reason A: Reference is not in the search path.
Reason B: Reference was deleted or does not exist.
If Reference is not red (resolved) but not visible:
Reference attachment may have a clip boundary and the elements in Reference file have been moved outside the clip boundary.
-Delete Clip boundaries to check and reclip reference as needed.
If Reference does not show up in Reference dialog:
The Active file is 2D, but a 3D file with the same name as the desired reference is being found before the desired 2D file (V7 files only).
-Check the found path and compare it to the desired 2D reference file's location.
You can point the variable MS_RFDIR to point to the desire location to find your reference files.
MS_RFDIR limitations
MS_RFDIR character limitations
Other language sources
DeutschItaliano
