| Version(s): | V8i | ||
| Area: | Configuration | ||
| Subarea: | General |
MicroStation does not seem to be taking advantage of all the memory available on my system. Is there anything I can do to improve MicroStation's performance?
Enable the policy "Lock pages in Memory". See the following Windows article for enabling this policy.
Enable the Lock Pages in Memory Option (Windows)
MicroStation V8 XM edition and later takes advantage of having more memory on your system.
Please refer to the MicroStation Memory Management article for more information regarding MicroStation and memory.
