1. REFERENCE DATE- The reference date will specify the first date used when calculating delta metrics indicated with the ∆. Specify the Reference date to use any ∆ Delta calculations.
Note: If no reference date is chosen, delta calculations will automatically use the first data point in your time range selected as the reference date.
2. EXTENSOMETER REFERENCE SENSOR- Users can specify an extensometer that will result in the calculation of some metrics, including ∆ Z of Head.
3. INSTALL ELEVATION- Users can input an install elevation for the extensometer. This will allow the calculation of elevation metrics for the selected extensometer.
4 INSTALL DIRECTION-  Users can input the install direction of the extensometer in order to correctly apply the measured displacement positively or negatively for calculated metrics.
5. SENSOR NAME- Users can modify the Sensor Name. This will change the name of the device that populates across the webpage.
6. SERIAL NUMBER- The user can input the serial number of the dEXTO device.
7. LOCATION- The Lat, Long and Elevation can be entered here.
Note: Whatever information that is entered here will determine where the sensors populate when using a Georeference Spatial profile.
8.  NOTES- Notes for the sensor can be added here.
9. APPLY- Click "Apply" to save the sensor configuration and be navigated back to the connectivity page.
