| Product: | MicroStation |
| Version: | V8i, CONNECT, 2023, 2024 |
| Environment: | N\A |
| Area: | Text |
| Subarea: | Fonts |
Message appears in Message Center:
"Replaced missing Font [FONT NAME] with [FONT NAME]. Some text may not display correctly."
You need to get the fonts that are listed as missing from the computer that was used to place the font. On the computer that correctly displays the font, copy the font(s) to the computer (same directory) that incorrectly displays the fonts.
MicroStation allows you to use three types of fonts by default. Each font is located in a different directory or folder location.
V8 and V8i delivered locations
True Type Fonts (.ttf) - these fonts are Windows fonts located in the Windows directory. (C:\Windows\Fonts) These fonts are the same fonts as used in Word and other MicroSoft Products
MicroStation Fonts (.rsc) - fonts delivered with MicroStation which may also be customized. By default they are located in the WorkSpace folder. If your Workspace is on your network or a different location locally you will need to find that location. (C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\System\Symb)
Autodesk Fonts (.shx) - these fonts are native to Autodesk products. MicroStation is delivered with some of these fonts. You may also get these from an outside source. These are standard AutoCAD fonts which can be found in the WorkSpace directory. (C:\ProgramData\Bentley\MicroStation V8i (SELECTseries)\WorkSpace\System\Fonts)
CONNECT delivered locations
True Type Fonts (.ttf) - these are still located in the Windows directory (C:\Windows\Fonts)
MicroStation Fonts (.rsc) - are now located in the Default Symb folder (C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Symb)
Autodesk Fonts (.shx) - located in the Default Fonts folder (C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\Default\Fonts)
MicroStation 2023/2024 delivered locations
True Type Fonts (.ttf) - located in the Windows directory (C:\Windows\Fonts)
MicroStation Fonts (.rsc) - are now located in the Default Symb folder (C:\Program Files\Bentley\MicroStation 202X\MicroStation\Default\Symb)
Autodesk Fonts (.shx) - are also located in the Default Fonts folder (C:\Program Files\Bentley\MicroStation 202X\MicroStation\Default\Fonts)
When you find the fonts that are missing or you have new fonts you would like MicroStation to find, you can add them to the locations listed. You may also use the variable MS_FONTPATH to point to a desired location other than the described locations.
If you are not sure what resource file contains the particular Font desired you can use Font Utility to open your resource files. See below Knowledge Base Article for information on the Font Utility tool.
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0108413
A detailed discussion on Fonts can be found here:
http://communities.bentley.com/products/microstation/w/microstation__wiki/8817.fonts-in-microstation
How to remove unused fonts from a design file
| Original Author: | Elisabeth Pry |
