| Version(s): | 08.09.04.47 | ||
| Area: | Programming | ||
| Subarea: | General | ||
Is there a plugin to add 2D Steel Structural Section profiles?
There is an old ma plugin for 2D Steel for pre-v8i version of
MicroStation.
Steel can be used for the placement of steel sections based on included
steel data tables.
Refer to steel.txt in the Library>Utilities>Steel after running the EXE
for installation instructions.
