| Version(s): | 08.11.09.578 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Programming | ||
| Subarea: | VBA | ||
| Original Author: | Tristan Anderson, Bentley Technical Support Group | ||
In addition to searchign the current model for specific items, it is also often necessary to search on all attached references. The treatment of references in the search, however, is very similar to looking into a model for a reference (attachment in VBA), one type per model.
Here is a small example in which all references are found by looking for lines, and the total number of lines found is output:
Sub refscan()
Dim Ee As ElementEnumerator
Dim SC As New ElementScanCriteria
Dim oAtt As Attachment
Dim count As Long
count = 0
SC.ExcludeAllTypes
SC.IncludeType msdElementTypeLine
For Each oAtt In ActiveModelReference.Attachments
Set Ee = oAtt.Scan(SC)
Do While Ee.MoveNext
count = count + 1
Loop
Next
MsgBox ("Total: " & count & " lines found in all references")
End Sub
The For-Next loop runs through all currently open models and their attached references. The variable "count" counts all found lines and is output at the end of the routine.
