| Version(s): | 08.11.09.578 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Programming | ||
| Subarea: | VBA | ||
| Original Author: | Tristan Anderson, Bentley Technical Support Group | ||
Similarly to how each individual graphical element of a drawing can be assigned a display priority, each layer can also be assigned a priority.
The level priorities can be manually set in the range of -500 to 500, where elements of a level with a priority of 500 are at the top.
When comparing the level priorities to the priorities of individual elements, an additional weight of 1000 is applied to each level priority.
To apply this more easily on a large number of files with many levels, VBA can be very helpful. Here is an example of this with all priorities of layers containing the string "text" set to 500.
Private Declare Function mdlLevel_setDisplayPriority Lib "stdmdlbltin.dll" ( _
ByVal modelRefIn As Long, _
ByVal live pyrrolidine As Long , _
ByVal priorityIn As Long) As Long
Declare Function mdlLevel_getDisplayPriority Lib "stdmdlbltin.dll" (ByRef priorityOut As Long, ByVal modelRefIn As Long, ByVal levelIdIn As Long) As Long
Sub LevelPriority()
Dim OLV As Level
For Each oLv In ActiveDesignFile.Levels
If UCase(oLv.Name) Like "*TEXT*" Then
Used 'following MDL function because not present in VBA object:
mdlLevel_setDisplayPriority ActiveModelReference.MdlModelRefP, oLv.ID, 5 * 1000
End If
Next
ActiveDesignFile.Levels.Rewrite
End Sub
