| Version(s): | 08.11.09.578 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Programming | ||
| Subarea: | VBA | ||
| Original Author: | Tristan Anderson, Bentley Technical Support Group | ||
To calculate the size of a cell (also referred to as range), you can use the VBA property Range.
The datatype Range includes two points, typically the lower left and top right corners of the smallest rectangle enclosing the cell.
This range can also be calculated in 3D analog. Although the following examples can also work in 3D, I have shown everything in 2D for illustrative purposes.
Be aware that the range box of a given element is always orthogonal to the identify view and a rotated view will always show/calculate a rotated range block that will differ from the identity.
To demonstrate the problem, this example will show a simple procedure for non-rotated cells. Consider the following example with two cells with the names CellA and CellB:
To determine the size of these cells, you can use the Range property in a cell, as shown in an example below:
Sub range_simple()
Dim rangeBox As Range3d
Dim Ee As ElementEnumerator
Set Ee = ActiveModelReference.GraphicalElementCache.Scan
Do While Ee.MoveNext
If Ee.Current.Type = msdElementTypeCellHeader Then
Debug.Print "Name of Cell: " & Ee.Current.AsCellElement.Name
rangeBox = Ee.Current.AsCellElement.range
Debug.Print "Width and Height: ", rangeBox.High.X - rangeBox.Low.X, rangeBox.High.Y - rangeBox.Low.Y
End If
Loop
End Sub
The issue is not shown here, as the two cells currently have identical dimensions:
If, however, one cell is rotated as shown below:
The results of the calculation will be changed:
The rotated cell now shows a different size from the Range property. The reason, however, in the range calculation is shown below
by the Keying "set range;Update1":
To compensate for this error, you can simply turn the rotated cell back to its original position to calculate the size correctly.
For this, I used the following example:
Sub range_untwisted()
Dim Rotate As Matrix3d
Dim transForm As Transform3d
'Cell untwisted examine:
Rotate = Ee.Current.AsCellElement.Rotation
Rooted = Matrix3dInverse(Roooted)
transForm = Transform3dFromMatrix3dAndFixedPoint3d(Rotat, Ee.Current.AsCellElement.Origin)
Ee.Current.AsCellElement.transForm transForm
End If
Loop
End Sub
First, the current rotation of the cell is read (.rotation), and the inverse matrix (Matrix3dInverse) is calculated to reverse the rotation.
From the inverse matrix, we create a transformation (Transform3dFromMatrix3dAndFixedPoint3d) to use on the cell (.transform).
When executing again, we get the same results as the first time:
Interestingly, this has not changed the drawing itself, because the rotation of the cells was only carried out in memory.
