| Application | PLAXIS 2D |
| Version | Latest version |
The construction of an embankment on soft soil with a high groundwater level leads to an increase in pore pressure. As a result of this undrained behaviour, the effective stress remains low and intermediate consolidation periods have to be adopted in order to construct the embankment safely. During consolidation, the excess pore pressures dissipate so that the soil can obtain the necessary shear strength to continue the construction process.
This lesson concerns the construction of a road embankment in which the mechanism described above is analysed in detail. In the analysis three new calculation options are introduced, namely a consolidation analysis, an updated mesh analysis and the calculation of a safety factor by means of a safety analysis (phi/c-reduction).
This exercise requires a PLAXIS 2D Advanced or PLAXIS 2D Ultimate license.
The provided *.p2dxlog file contains all the commands to generate the model. With a Bentley Geotechnical SELECT Entitlement [GSE] license, you can use the link to save as the file (remove the extension .txt) and with the Commands runner open to execute all commands in one go, see also this instruction.
