| Version(s): | V8i, CONNECT, 2023 | ||
| Area: | Base Geometry | ||
| Subarea: | N\A |
I've created a shape, but now I need to add or delete a few points.
In the “Drawing” section of the ribbon there is a “Modify” column.
Here you can use various options to modify an element. When it comes to the vertexes, you can insert / delete / extend them along a line.
Please look at the uploaded video below.
