PLAXIS 2D Tutorial 07: Dry excavation using a tie back wall
Application PLAXIS 2D
Version Latest version
This example involves the dry construction of an excavation. The excavation is supported by concrete diaphragm walls. The walls are tied back by prestressed ground anchors.
PLAXIS allows for a detailed modelling of this type of problem. It is demonstrated in this example how ground anchors are modelled and how prestressing is applied to the anchors. Moreover, the dry excavation involves a groundwater flow calculation to generate the new water pressure distribution. This aspect of the analysis is explained in detail.
This exercise requires a PLAXIS 2D Advanced or PLAXIS 2D Ultimate license.
The provided *.p2dxlog file contains all the commands to generate the model. With a Bentley Geotechnical SELECT Entitlement [GSE] license, you can use the link to save as the file (remove the extension .txt) and with the  Commands runner open to execute all commands in one go, see also this instruction.
Downloads
See also
