| Version(s): | CONNECT, MicroStation 2023 | ||
| Area: | Exception | ||
| Subarea: | N\A |
MicroStation crashes on start up
Ideally collect the following, log a Service Case and work with the Support team in troubleshooting the issue.
• Crash logs - check video
• Event logs - check video
The following workaround of “Create new UPF file” has fixed the crashes for some Users.
Note: Your current User Preference settings, will be lost when you create a new UPF file.
Create new UPF file
• Close the product
• Backup the following UPF file from the following location. Rename Personal.upf to Personal.bak
C:\Users\{UserName}\AppData\Local\Bentley\MicroStation\23.0.xx\prefs\Personal.upf
• Open MicroStation and check if it loads
The User Preference File [UPF]
| Original Author: | Leonard Jones |
