Product(s): |
MicroStation |
Version(s): |
MicroStation CONNECT Edition Update 16 and greater |
Environment: |
N\A |
Area: |
Database |
Subarea: |
N\A |
MicroStation supported databases:
MicroStation supports many of the popular relational database software product families on the market today. Selecting the right one can be difficult as these databases represent a broad range in sophistication, performance and cost. You can implement anything from a simple single-user database on a computer to a full featured corporate network system with database servers and different vendor databases all interacting with the same design files.
- ODBC
- Microsoft Access 2010 (64 bit)
- Microsoft Access 2013 (64 bit)
- Microsoft Access 2019 (64 bit)
- SQL Server 2012 (64 bit)
- SQL Server 2014 (64 bit)
- SQL Server 2016 (64 bit)
- SQL Server 2017 (64 bit)
- SQL Server 2019 (64 bit)
- Oracle 11g (64 bit)
- Oracle 12c (64 bit)
- Oracle 19c (64 bit)***
- Oracle 21c(64 bit)*****
- OLEDB
- Oracle
- Oracle 19c (64 bit)****
- BUDBC_SQLServer
- SQLServer 2012 (64 bit)
- SQLServer 2014 (64 bit)
- SQLServer 2016 (64 bit)
- SQLServer 2017 (64 bit)
- SQLServer 2019 (64 bit)
- BUDBC_OLEDB
- BUDBC_ORACLE
** MicroStation CONNECT Edition 10.16.01.xx and lower
*** MicroStation CONNECT Edition 10.16.01.xx and higher
**** MicroStation CONNECT Edition 10.16.02.xx and higher
***** MicroStation CONNECT Edition 24.00.02.xx and higher
Other Language Sources
Español
Français
Italian
Turkish
Deutsch
