| Version(s): | V8i, CONNECT, 2023 | ||
| Area: | Printing and Plotting | ||
| Subarea: | N\A | ||
| Original Author: | Beverly Dawn Gentry, Bentley Technical Support Group |
Update fields do not get updated properly when plotting from Print Organizer and Batch plot.
Make sure the following MS variables are set:
MS_PLT_UPDATE_FIELDS=1
MS_AUTO_UPDATE_FIELDS=ALWAYS
In addition, the file must be opened Read/Write by the plotting interface.
For Print Organizer, set:
MS_PRINTORGANIZER_OPEN_DGN_READWRITE=1
For Batch plot, set:
MS_BATCHPRINT_NO_READONLY = 1
Note - a valid workaround would consist of applying a batch process with following command script to each file before creating print sets/definitions and printing with Print Organizer:
fit view extended;
selview 1;
field update all;
reset;
