| Version: | CONNECT & MicroStation 2023 - 2025 | ||
| Environment: | Windows | ||
| Area: | N/A | ||
| Subarea: | N/A |
Event logging provides a standard, centralized way for applications (and the operating system) to record important software and hardware events. Event logs are required for system administrators or support representatives to diagnose problems.
Kindly save the Application and System logs, share it with Bentley support.
To get the system and application logs:
communities.bentley.com/.../274876
Deutsch , Français , Italian Español
| Original Author: | Leonard Jones |
