| | Product: | MicroStation | |
| | Version: | All versions | |
| | Environment: | N\A | |
| | Area: | Interchange | |
| | Subarea: | Google Earth | |
How to
Capture Google Earth Images Using Placemark Monuments
Steps
- Create Placemarks in Google Earth.
- In Google Earth, click “Add Placemark” from the toolbar, or in the menu click Add > Placemark.
- A Placemark will appear in the center of the Google Earth view. Drag it to a reference location that is also in the MicroStation model.
- In the “Google Earth – New Placemark” dialog, enter a name and click OK.
- Repeat for additional reference points.
- Save Placemark in Google Earth.
- In Google Earth, right-click on each placemark and select “Save Place As”.
- Note the directory, and click Save.
- Repeat for all additional placemarks.
- Add Placemark Monuments to MicroStation.
- In MicroStation, go to: Tools > Geographic > Define Placemark Monument.
- In the “Define Placemark Monument” dialog, select the source “Google Earth Placemark File”.
- Click on the magnifying glass symbol.
- In the “Select Placemark files” dialog, select the KMZ file(s) containing the placemark monuments that were saved from Google Earth (step 2).
- Click Done.
- Place the placemark(s) to the corresponding reference location(s) in MicroStation.
- In Google Earth, zoom to the location to capture.
- Capture Google Earth Image in MicroStation.
- Go to: Tools > Geographic > Capture Google Earth Image.
- Enter a data point to capture the current Google Earth view.
- Repeat steps 4-5 as needed.
Other Language Sources
Italiano
| | Original Author: | Craig Calvin | |
