| Version(s): | 08.11.09.459, CONNECT, 2023 | ||
| Area: | Printing | ||
| Subarea: | Dialog | ||
| Original Author: | Frank Reimann, Bentley Technical Support Group | ||
How to set the default printer using a MicroStation Configuration variable?
You can use the MicroStation variable MS_PLT_SYSPRT_DEFAULT_PRINTER
Example:
MS_PLT_SYSPRT_DEFAULT_PRINTER = HP DesignJet T770 by Bentley
