| Version(s): | 08.11.09.459, CONNECT, 2023 | ||
| Area: | Printing | ||
| Subarea: | Dialog | ||
How to set the default printer driver configuration file using a MicroStation Configuration variable?
If MS_DEFAULT_PLTCFG_FILE is set to a printer driver configuration filename, that file (instead of the most recently used one) is selected when you open the Print dialog box. The value of this variable may be either a .pltcfg or .plt file.
