IoT Configuration
If you are an iTwin IoT user, you can link the output of your sensor to iTwin Experience.
To connect to the iTwin IoT, go to the IoT tile on the Configuration page and click "Enable".
You will land on the IoT Connectivity page.
Please refer to iTwin IoT to set your sensor's connectivity.
