Conversion of PLAXIS 2D files
Application PLAXIS 2D
Version PLAXIS 2D - all versions
Date created 06 March 2015
Date modified 29 October 2026
Due to adding more features and improving the program’s data structure for stability and performance, the data structure of the PLAXIS data files has evolved over time.
PLAXIS 2D 2026.1
PLAXIS 2D 2026.1 can read PLAXIS *.p2dx files created with PLAXIS 2D 2025.1, PLAXIS 2D 2024 (all versions), PLAXIS 2D 2023 (all versions), PLAXIS 2D CONNECT Edition V22 (all versions), PLAXIS 2D CONNECT Edition V21 (all versions), PLAXIS 2D CONNECT Edition V20 (all versions), PLAXIS 2D 2019 (all versions), PLAXIS 2D 2018 (all versions), PLAXIS 2D 2017 (all versions), PLAXIS 2D 2016 (all versions) or PLAXIS 2D 2015 (all versions). To open projects created with PLAXIS 2D AE (any version), you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version can be installed next to PLAXIS 2D 2026.1.
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D 2026.1.
See also Video: PLAXIS 2D Classic Converter for CONNECT Edition
PLAXIS 2D 2025.1
PLAXIS 2D 2025.1 can read PLAXIS *.p2dx files created with PLAXIS 2D 2024 (all versions), PLAXIS 2D 2023 (all versions), PLAXIS 2D CONNECT Edition V22 (all versions), PLAXIS 2D CONNECT Edition V21 (all versions), PLAXIS 2D CONNECT Edition V20 (all versions), PLAXIS 2D 2019 (all versions), PLAXIS 2D 2018 (all versions), PLAXIS 2D 2017 (all versions), PLAXIS 2D 2016 (all versions) or PLAXIS 2D 2015 (all versions). To open projects created with PLAXIS 2D AE (any version), you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version can be installed next to PLAXIS 2D 2024.3.
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D 2025.1.
PLAXIS 2D 2024.3
PLAXIS 2D 2024.3 can read PLAXIS *.p2dx files created with PLAXIS 2D 2024.2, PLAXIS 2D 2024.1, PLAXIS 2D 2023.2.1, PLAXIS 2D 2023.2, PLAXIS 2D 2023.1, PLAXIS 2D CONNECT Edition V22 Update 2, PLAXIS 2D CONNECT Edition V22 Update 1, PLAXIS 2D CONNECT Edition V22, PLAXIS 2D CONNECT Edition V21 Update 1, PLAXIS 2D CONNECT Edition V21, PLAXIS 2D CONNECT Edition V20 Update 4, PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016 or PLAXIS 2D 2015. To open projects created with PLAXIS 2D AE, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version replaces PLAXIS 2D 2024.2.
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D 2024.3.
PLAXIS 2D 2024.2
PLAXIS 2D 2024.2 can read PLAXIS *.p2dx files created with PLAXIS 2D 2024.1, PLAXIS 2D 2023.2.1, PLAXIS 2D 2023.2, PLAXIS 2D 2023.1, PLAXIS 2D CONNECT Edition V22 Update 2, PLAXIS 2D CONNECT Edition V22 Update 1, PLAXIS 2D CONNECT Edition V22, PLAXIS 2D CONNECT Edition V21 Update 1, PLAXIS 2D CONNECT Edition V21, PLAXIS 2D CONNECT Edition V20 Update 4, PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016 or PLAXIS 2D 2015. To open projects created with PLAXIS 2D AE, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version replaces PLAXIS 2D 2024.1.
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D 2024.2.
PLAXIS 2D 2024.1
PLAXIS 2D 2024.1 can read PLAXIS *.p2dx files created with PLAXIS 2D 2023.2.1, PLAXIS 2D 2023.2, PLAXIS 2D 2023.1, PLAXIS 2D CONNECT Edition V22 Update 2, PLAXIS 2D CONNECT Edition V22 Update 1, PLAXIS 2D CONNECT Edition V22, PLAXIS 2D CONNECT Edition V21 Update 1, PLAXIS 2D CONNECT Edition V21, PLAXIS 2D CONNECT Edition V20 Update 4, PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016 or PLAXIS 2D 2015. To open projects created with PLAXIS 2D AE, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version replaces PLAXIS 2D 2023.2.
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D 2024.1.
PLAXIS 2D 2023.2
PLAXIS 2D 2023.2 can read PLAXIS *.p2dx files created with PLAXIS 2D 2023.1, PLAXIS 2D CONNECT Edition V22 Update 2, PLAXIS 2D CONNECT Edition V22 Update 1, PLAXIS 2D CONNECT Edition V22, PLAXIS 2D CONNECT Edition V21 Update 1, PLAXIS 2D CONNECT Edition V21, PLAXIS 2D CONNECT Edition V20 Update 4, PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016 or PLAXIS 2D 2015. To open projects created with PLAXIS 2D AE, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version replaces PLAXIS 2D 2023.1.
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D 2023.2.
PLAXIS 2D 2023.1
PLAXIS 2D 2023.1 can read PLAXIS *.p2dx files created with PLAXIS 2D CONNECT Edition V22 Update 2, PLAXIS 2D CONNECT Edition V22 Update 1, PLAXIS 2D CONNECT Edition V22, PLAXIS 2D CONNECT Edition V21 Update 1, PLAXIS 2D CONNECT Edition V21, PLAXIS 2D CONNECT Edition V20 Update 4, PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016 or PLAXIS 2D 2015. To open projects created with PLAXIS 2D AE, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version can be installed next to PLAXIS 2D CONNECT Edition V22 (all Updates).
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D 2023.1.
PLAXIS 2D CONNECT Edition V22 (incl. Update 1 and Update 2)
PLAXIS 2D CONNECT Edition V22, PLAXIS 2D CONNECT Edition V22 Update 1 and PLAXIS 2D CONNECT Edition V22 Update 2 can read PLAXIS *.p2dx files created with PLAXIS 2D CONNECT Edition V21 Update 1, PLAXIS 2D CONNECT Edition V21, PLAXIS 2D CONNECT Edition V20 Update 4, PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016 or PLAXIS 2D 2015. To open projects created with PLAXIS 2D AE, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. This version can be installed next to PLAXIS 2D CONNECT Edition V21 Update 1.
In order to convert older files from PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D, you can install the PLAXIS 2D CONNECT Edition V21 Update 1. Then, the older files from projects can be directly converted to PLAXIS 2D CONNECT Edition V21 Update 1 right from the Input program, which can be opened in PLAXIS 2D CONNECT Edition V22.
PLAXIS 2D CONNECT Edition V21 (incl. Update 1)
PLAXIS 2D CONNECT Edition V21 and PLAXIS 2D CONNECT Edition V21 Update 1 can read PLAXIS *.p2dx files created with PLAXIS 2D CONNECT Edition V20 Update 4, PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE.
With this release, it is possible to convert older files from PLAXIS with our CONNECT Edition. This means that older PLAXIS files with the *.P2D can directly be converted to PLAXIS 2D CONNECT Edition V21 (and V21 update 1) right from the Input program!
This includes files last saved in PLAXIS 2D 2010, 2D 2011, 2D 2012 and PLAXIS 2D Classic, all with the file extension *.P2D.
PLAXIS 2D CONNECT Edition V20 Update 4 can read PLAXIS *.p2dx files created with PLAXIS 2D CONNECT Edition V20 Update 3, PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE. This version replaces PLAXIS 2D CONNECT Edition V20 Update 3.
With this release, we reintroduced the ability to convert older files from PLAXIS with our CONNECT Edition. This means that older PLAXIS files with the *.P2D can directly be converted to PLAXIS 2D CONNECT Edition V20 Update 2 right from the Input program!
PLAXIS 2D CONNECT Edition V20 Update 3 can only read PLAXIS *.p2dx files created with PLAXIS 2D CONNECT Edition V20 Update 2, PLAXIS 2D CONNECT Edition V20 Update 1, PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE.
Tip: The procedure of keeping both versions of 2D AE and 2D CONNECT Edition V20 installed on the same computer for the conversion of older files is described in the related article on how to Install latest 2D version and 2D AE for converting old files.
PLAXIS 2D CONNECT Edition V20 can only read PLAXIS *.p2dx files created with PLAXIS 2D CONNECT Edition V20, PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE.
PLAXIS 2D 2019
PLAXIS 2D 2019 can only read PLAXIS *.p2dx files created with PLAXIS 2D 2019, PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE.
Tip: The procedure of keeping both versions of 2D AE and 2D 2019 installed on the same computer for the conversion of older files is described in the related article on how to Install latest 2D version and 2D AE for converting old files.
PLAXIS 2D 2018
PLAXIS 2D 2018 can only read PLAXIS *.p2dx files created with PLAXIS 2D 2018, PLAXIS 2D 2017, PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE.
Tip: The procedure of keeping both versions of 2D AE and 2D 2018 installed on the same computer for the conversion of older files is described in the related article on how to Install latest 2D version and 2D AE for converting old files.
PLAXIS 2D 2017
PLAXIS 2D 2017 can only read PLAXIS *.p2dx files created with PLAXIS 2D 2017, PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE.
Tip: The procedure of keeping both versions of 2D AE and 2D 2017 installed on the same computer for the conversion of older files is described in the related article on how to Install latest 2D version and 2D AE for converting old files.
PLAXIS 2D 2016
PLAXIS 2D 2016 can only read PLAXIS *.p2dx files created with PLAXIS 2D 2016, PLAXIS 2D 2015 or PLAXIS 2D AE.
Tip: The procedure of keeping both versions of 2D AE and 2D 2016 installed on the same computer for the conversion of older files is described in the related article on how to Install latest 2D version and 2D AE for converting old files.
PLAXIS 2D 2015
PLAXIS 2D 2015 can only read PLAXIS *.p2dx files created with PLAXIS 2D 2015 or PLAXIS 2D AE.
PLAXIS 2D 2015 cannot use the 2D Classic to 2D AE converter to convert older Plaxis *.P2D files into the data format needed for PLAXIS 2D 2015. In order to use *.P2D files (2D Classic and earlier) in PLAXIS 2D 2015, these files first need to be converted to the PLAXIS 2D AE format using a PLAXIS 2D AE installation in combination with the 2D Classic to 2D AE converter installation, see below.
After this, you can open these 2D AE files in PLAXIS 2D 2015.
Tip: The procedure of keeping both versions of 2D AE and 2D 2015 installed on the same computer is described in the related article of how to Install latest 2D version and 2D AE for converting old files.
PLAXIS 2D AE
With PLAXIS 2D AE, the file extension was changed from *.P2D to *.p2dx. PLAXIS 2D AE can only read files made with PLAXIS 2D AE (*.p2dx). Plaxis project files created with the PLAXIS 2D 2012 version or earlier (with extension .P2D) cannot be opened directly in PLAXIS 2D AE: they first need to be converted using the 2D Classic to 2D AE converter.
PLAXIS 2D AE version license can only be provided using a Codemeter dongle (CmStick).
The 2D Classic to 2D AE converter is an add-on program for PLAXIS 2D AE. In PLAXIS 2D AE when opening a 2D classic file (*.P2D) this converter program will be called, and it will transform the old PLAXIS 2D project via 2D AE's command line into the new format. Note that this Converter is intended to only work directly from PLAXIS 2D AE, and it is not intended to start the Converter manually. Please follow these steps to convert the older PLAXIS data to the new version:
Please note that in order to perform all the above-mentioned procedures, you need to have the PLAXIS 2D Classic to 2D AE converter installed. This tool comes with the full setup of PLAXIS 2D AE as an option during the installation procedure of the PLAXIS software. Next to this, it is also available as a separate program via PLAXIS Connect.
For older PLAXIS files (PLAXIS 2D V8 and V9): these files first need to be converted to PLAXIS 2D Classic before it can be converted into the 2D AE data format, see below or the related page:
Conversion from 2D Version 8/9
PLAXIS 2D 2010 - 2011 - 2012 - Classic
With PLAXIS 2D 2010, the file extension was changed from *.PLX to *.P2D. PLAXIS 2D 2010 to PLAXIS 2D Classic was capable of reading in files created with earlier versions starting from Version 8.2 (with extension *.plx).
To convert PLAXIS 2D V8/V9 files, it is recommended to use PLAXIS 2D Classic.
PLAXIS 2D Version 9
PLAXIS 2D Version 9 can read *.PLX files made with PLAXIS 2D Version 8 and PLAXIS 2D Version 9.
PLAXIS 2D Version 8
PLAXIS 2D Version 8 was the only program available that could convert PLAXIS 2D Version 7 files into the newer file structure for the *.PLX file.
All dongle/hardware lock (HWL) based versions of PLAXIS 2D/3D are treated as "V8i SELECTseries 10" according to Bentley's Support Policy. This means that Bentley will discontinue support for hardware lock based versions of PLAXIS after December 31, 2021. This includes PLAXIS 2D 2019 and older, and PLAXIS 3D 2018 and older.
To see the benefits of the latest versions and how to get the latest version, please see PLAXIS CONNECT Edition: upgrade from Hardware lock to Flexible licensing
See also
