The Photo Navigation offers a consistent photo consumption experience across all of Bentley's « Powered by iTwin » web applications.
Prior to being able to use the Photo Navigation tool, a Mapping Ressource must be created and associated with the asset. For more information on these steps, go to the Publish result of a iTwin Capture Modeler aerotriangulation for the Photo Navigation page.
Once the Mapping Resource is created, it must be associated with the Asset . For more information on how to associate reality data with an asset, go to the Reality Data section.
1) Open the Model asset, in the Reality Data widget, turn ON the reality data you want to use with the photo navigation.
2) Still in the Reality Data widget, click the "Photo Navigation" tab.
3) Turn On the Photo navigation resource file. A new viewport is added to the right of the Reality Data Web Viewer's application window.
4) Optionally use the "Model" tab at the top of the Reality Data Widget to manage the display of Reality Data in the left-most viewport.
The Photo Navigation Settings dialog contains settings allowing you to enable different options.
Show camera position - When the toggle is enabled, the camera positions are displayed in the the left view. The cameras can be displayed as Dot or Cone.
Camera scale factor - When the Cone option is selected, the camera scale factor appears, allowing you to change the scale factor of the cameras.
Apply occlusion on cameras - This feature hides camera positions that are physically behind the object you are viewing. For example, when looking at the top of a bridge deck, you will only see the camera positions relevant to that view, not those pointing underneath the bridge.
On the left hand side of the viewer, you can find the Photo navigation tool. This toolbar contains two different tools.
Select Point of Interest - Click on Select Point of Interest and click in the model view. The photos showing that point are listed in the Photo Navigation view. You can select a thumbnail in the carousel at the bottom and see the high-resolution corresponding photo.
Select Camera - Click the Select Camera option, the photo corresponding to the selected camera will be displayed in the Photo Navigation view.
Related:
